Scriptrunner description field formatting help
Autumn Justice June 8, 2023
Hi!
I'm currently writing a script to auto-populate the description field with info-paneled text on a specific ticket type, using the script runner "behaviors" feature.
My main issue is that I've got no formal JS training, so something is wonky with my script, but I'm not sure what...I'd appreciate any help with troubleshooting the below code!
I've attached the screenshots of what I'd like the formatted ticket template to look like, and the main error message I'm getting when writing the code in behaviors (pretty sure I just have no idea how to add multiple parameters one after the other correctly).
Thank you for any help here!
const descriptionValue = getFieldById("description").getValue();
const descriptionValueContent = descriptionValue.content.toString();
if (!descriptionValueContent) {
getFieldById("description").setValue({
"version": 1,
"type": "doc",
"content": [
"type": "panel",
"attrs": {
"panel type": "info"
"content": [
"type": "paragraph",
"content": [
"type": "text",
"text": "Hypothesis:"
"type": "panel",
"attrs": {
"content": [
"content": [
"type": "text",
"text": "Goal:"
"type": "panel",
"attrs": {
"content": [
"content": [
"type": "text",
"text": "Estimated Business Impact:"
"type": "panel",
"attrs": {
"content": [
"content": [
"type": "text",
"text": "Needed By:"
"type": "panel",
"attrs": {
"content": [
"content": [
"type": "text",
"text": "Background/Details:"
Initial error I'm getting returned:
Goal for formatted ticket:
Evgenii
include description text to triple quotes
getFieldById("description").setValue("""very long description
in a few lines
with some variables ${var1} and ${var2} in body""")
Tim Perrault
June 8, 2023
Evgeniy answer should be good and just use wiki markup to get the panels and stuff
{panel:bgColor=#deebff}
(i) Hypothesis:{panel}"""
Like Evgenii likes this
Kristian Walker (Adaptavist)
Hi Autumn,
I can confirm that you need to use Atlassian Document Format when setting the description field.
Atlassian provides the Atlassian Document Format Builder tool, and you can use this to create the formatting you want in the visual editor.
It will then generate the Atlassian Document format Code that you can paste into the script to set the description field.
I hope this helps.
Kristian
Romain Dubousquet November 5, 2024
Hello guys,
Just wanted to let you know that I tested it 5 minutes ago and it works with this code :
const descriptionField = getFieldById("description");
const descriptionValue = descriptionField.getValue();
// Check if the description field is empty or not a string
if (!descriptionValue || typeof descriptionValue !== "string") {
    descriptionField.setValue({
        "version": 1,
        "type": "doc",
        "content": [
                "type": "panel",
                "attrs": {
                    "panelType": "info"
                "content": [
                        "content": [
                                "type": "text",
                                "text": "Hello world"
And this is what I got :
Hope it helps, have a good day !
Jesus Octavio Gutierrez Villegas
Hello, sorry I have a question, anyone knows how to create a table with Behaviour for my Description field?
Hi Jesus,
To create a table, you will need to use Atlassian Document Format and you can use the Atlassian document format builder tool mentioned in my post above to generate the Atlassian document format code for this.
Kristian
Also sorry -Can't get this Jira forum to paste the code block with appropriate indents and spacing.
