×Hello,
I am trying to find all the epics that exist that are not linked to a certain project epic.
So i want to ensure that everything has a link to an epic in project X, so i need a list of them.
I have the below but it times out and im pretty sure its not right.
issuetype = epic and project = "YYY" AND issueFunction in linkedIssuesOf("project not in ("XXX")")
Also this is on cloud
Where am i going wrong?
this is a tricky one. The problem with your current JQL query
is that
will return all issues that are linked to any issues in
which I don't think is what you want.
What you would need is a function like hasIssueLinksIn(query) (or probably even better, hasNoIssueLinksIn(query) - which I don't think is available.
Taking a step back: Do I understand correctly that the epics that you want to find have
Best,
Hannes
Actually @Alistair Attrill
here's another thought: I may be easier to query the epics that are linked correctly, and then basically "invert" the result.
So if I understand you correctly, this should give you the "correct" epics:
issuetype = epic and project = "YYY" AND issueFunction in linkedIssuesOf("project = XXX")
IIRC, you should be able to save this as a filter, and then use a
filter != <your filter ID>
clause to invert the result?
If this doesn't work for some reason, you could take the first query, add a label using bulk edit (like, I don't know, good-epic), and then query for labels != good-epic.
There are third party plugins (like ScriptRunner by Adaptavist) that extend the functionality of JQL and will allow you to find linked issues in other projects.
Yeah I have that app but i cant quite work out the JQL to make it happen.
Thanks for the effort on this, but I would like to list the TATA that are not linked to a GLOB-X. Does that make the sense.
As every TATA should be linked to a GLOB.
