Search URL return only ID not issue values
vishnu palani June 19, 2025
I was using searchURL to get results from a filter. It was working fine for a few days and returned all the fields of the issues. However, recently, due to some permission changes, this search URL now returns only issue IDs instead of the full issue details
Priyanka Khare
June 19, 2025
The issue is likely due to permission changes. To fix it:
  1. Check Permissions: Ensure you have access to all issue fields in the Permission Scheme.
  2. Review Issue Security: Make sure issues aren't restricted by issue security levels.
  3. Adjust Filter Sharing: Confirm the filter is shared with users who have permission to view all fields.
Test with admin access to confirm if it's a permissions issue.
vishnu palani July 22, 2025
i trying with Admin account only
Aron Gombas _Midori_
What do you mean by "search URL"?
Are you using the Jira Cloud REST API? If so, which end-point?
i am tell about this API reasponse
Rilwan Ahmed
Hi @vishnu palani ,
Welcome to the community !!
In your filter results, try to add the required fields in the columns. i.e. Scroll to the right end of the filter results, click on "+" and select the fields you wish to see under "My defaults".
FREE
