Search for issues: JQL not caught
Sara V. October 25, 2022
Hi everyone!
I would like to create a filter, and I've inserted the following code in the advanced research:
JQL code.JPGAs you can see in the attached screenshot, the code seems to be accepted.
However on checking I can still see the customized icon CI and WG.
@lucale
Thank you in advance!
4 votes
Walter Buggenhout
Hi @Sara V.,
Yes. The way you put things here, the OR part is basically ensuring that all issues are returned:
Issuetype != CI
will return all issue types in your Jira instance apart from CI (so also WG).
Issuetype != WG
will return all issue types in your Jira instance apart from WG (so also CI).
Assuming that you want to return all issues that are not CI and not WG, try the following instead:
category = "System Design" AND issuetype NOT IN (CI, WG)
Hope this helps!
Thank you @Walter Buggenhout !
I had already tried the AND operator, but without changing the 'format' of the sentence. Now it works!
Thank you :)
Sorry and if I wanted to add that, in addition of having issuetype different from CI and WG, I also want all those in the 'system design' that have the custom field 'project platform' different from 'POC', I should write the code like this:
code.JPG?
because it does not take it correctly.
Walter Buggenhout
Depends what the desired result needs to be, @Sara V.. As soon as you start using OR in your JQL, you need to make sure to use parentheses in the right places to get the desired results:
category = "System Design" AND issuetype NOT IN (CI, WG) AND
"Project Platform" != POC
would return all issues from system design projects that or not CI or WG issue types and on top of that do not have the value POC for Project Platform
category = "System Design" AND (issuetype NOT IN (CI, WG) OR
"Project Platform" != POC)
because of the placement of your parentheses will return issuetypes CI and WG again. Whereas:
(category = "System Design" AND issuetype NOT IN (CI, WG)) OR
will even return issues from other projects, again simply because of where you put your parentheses.
And, to make things even more exciting: if you search for custom field values, Jira also has a tendency to ignore empty values in that search. You might even need to do something like this:
"Project Platform" != POC AND "Project Platform" is NOT EMPTY
That last example goes back to the first scenario here, because I assume that's most likely what you want to achieve. If you do want empty values to be returned, that would become something like this:
("Project Platform" != POC OR "Project Platform" is EMPTY)
Note the placement of the parentheses here as well as the use of OR, because I am combining different criteria for the same field.
Like Sara V. likes this
@Walter Buggenhout thank you!
I am not an expert of JQL code,
Thank you very much for the explanation: super super clear!
Like Walter Buggenhout likes this
Bill Sheboy
October 25, 2022
Hi @Sara V.
Adding to Walter's answer...There is some free, online training from Atlassian on JQL, such as this class below:
https://university.atlassian.com/student/path/849533-gain-project-insights-through-jql
This one helps to learn how you might answer project questions using JQL.
FREE
