Searching Issues where comment field does not include text
Maria Del Rosario Gonzalez
I am working on JIRA Cloud and would like to get a list of records where a certain comment does not appear.
This works perfectly when the JQL is comment ~ "String" but the opposite does not.  I have tried using comment !~ "String" or NOT (comment ~ "String") also single quotes around String.
Lastly, the String = Baseline so it does not have any special characters.
Many thanks in advance!
5 votes
Harald Seyr
September 20, 2022
Hi @Maria Del Rosario Gonzalez
the search for "comment !~ String" or "NOT (comment ~ String)" probably does not work because JQL checks if any other comment exists that does not contain the text.
Since JQL does not support subqueries / subselects in a direct way, the only solution I can think of is a little complicated.
  • select the issues containing the text in comment, e.g. comment ~ String
  • save this as a filter, e.g. "MyCommentFilter"
  • select all issues not in the filter by JQL like "filter not in (MyCommentFilter)"
Please make sure that after saving the filter in second step, reset the search form not to show the "MyCommentFilter" anymore, otherwise Jira will display an obscure error message about cyclic dependencies.
Harald
Thanks Harald, this worked!  Much appreciate the prompt response!!
Amy
May 10, 2024
Worked for me too, Thank You!!
Waqar Hasan Khan
October 15, 2024
it works thanks
