Searching for an Issue by Field
fza July 12, 2019
Using the REST API, is there a way I can get an issue by searching for a value in one of its fields?
Warren
July 12, 2019
Hi @fza
You could use the search call as shown here - it accepts any JQL, so as long as you're able to articulate the query, it should work, something like
/rest/api/3/search?jql=fieldxx~"find_string"
This will most likely work for text-type fields, not too sure for others
fza July 12, 2019
Will this work with custom fields as well?
Warren
July 15, 2019
Yes, you can use
custom_field_12345 ~ "find_string"
for text fields
Like fza likes this
