Security level field is not visible on issue create/edit issue screen
Glen2021 May 1, 2021
Hi Team,
I am new to Jira and facing an below issue.
On the project screen I have a security level field available but I am not able to see it while creating or editing an issue.
Not sure whats the issue, can anyone please help
3 votes
Sagar Mahajan
Hi @Glen2021
Can you please check if issue security scheme is attached the project from the project summary page.
If there is no security scheme associated to the project you will not able to see the field on issue operation screen.
@Sagar Mahajan Thanks for the reply but I don't have access to check this, will let admin about this.
Like John Funk likes this
Nic Brough -Adaptavist-
May 1, 2021
You should also check that your people have the "set security level" permission in the project.  The level field will not appear on create/edit/transition if they do not.
Like # people like this
