Send Email from Jira Automation - From Sender email address has changed.
Maximilian Floß June 1, 2023
I am wondering regarding the sender email address from the automation action "Send email". The previous Sender address was always: "noreply@automation.atlassian.net".
Since today the sender address is "automation@company.atlassian.net.
Has somebody else experienced this change?
Where can I find some information regarding this?
John Funk
Valerie Knapp
Hi @Maximilian Floß , thanks for your question.
If you go into the automation rule and then the audit log, you should be able to see a record of any recent changes.
and then, in the action, Send email, you can click on More options to specify the from address and the reply to, if you want one.
Hope this helps.
Cheers
@Valerie Knapp
I am not interested in the Audit log and changes in my defined automation. I am wondering about the From section in the More options button.
The Email address from which the email is sent has changed from "noreply@automation.atlassian.net" to "automation@company.atlassian.net."
Like Tyler Kosaski likes this
