Send Slack as DM using automation - No channel
Hizkeel Khan
I want to send slack message directly to someone instead of putting it in the channel. Please let me know how I can do it using automation.
If it's necessary to send message in channel, can I mention that person everytime when rule triggers.
Mohanraj Thangamuthu
September 10, 2024
Hello, Good day. Have you already tried the following stepsScreenshot 2024-09-11 at 10.30.35 AM.png?
https://support.atlassian.com/cloud-automation/docs/use-automation-with-slack/
Hizkeel Khan
@Mohanraj Thangamuthu - Thank you for the response. Here it is mentioning the reporter. I want to notify the client in the channel when ticket moves to the UAT column.
Hizkeel Khan
I want to tag someone... where it says "hey team" , I need to mention someone instead
September 12, 2024
Hello, As the ID in Jira and Slack will be different, there is no direct method. You can try the steps suggested in https://community.atlassian.com/t5/Jira-questions/Send-automatically-notification-with-direct-message-when-user-is/qaq-p/2157225
FREE
