Send comment to reporter
Giorgos A Tsavegias
Hi community,
I created an automation which send a comment to the reporter of an issue, when the linked issue's status changes.
The point is that when eg the status changes from A to B, the comment is created :
@userx linked issue status B.
When i transition the issue from status B to C,
the comment is also created but substitues also the first comment and now i have 2 comments:
@userx linked issue status C
@userx linked issue status C instead of @userx linked issue status B.
Fabian Lim
Hi @Giorgos A Tsavegias
I would create separate transition rules that are specific to each transiton. I hope it helps.
Regards
Giorgos A Tsavegias
Hi @Fabian Lim unfortunatelly it did not work.
atarab
Hi @Giorgos A Tsavegias ,
Can you please send the full body of the comment in the automation builder? It is cut off in the picture.
Giorgos A Tsavegias
