Set Project Lead with Script Runner
Deleted user March 16, 2018
I trying write code in groovy script runner to create project from post function level in JIRA. Everything going well, but i can't find any solution to change Project Lead for project. I saw that possible is change default assignee, but i can't find any information about Project Lead. Meybe anyone found solution for this. I just need example for specific function. I will be very grateful for help!
Wojciech Miecznikowski
Alexey Matveev
March 16, 2018
Deleted user March 19, 2018
Big thanks! This is it what i need. I just have problems with implementing this method:
[Static type checking] - Cannot find matching method com.atlassian.jira.project.ProjectManager#updateProject(java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object). Please check if the declared type is right and if the method exists.
Do you have any idea?
simple example:
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
def originalproject = "TESTOR"
def name = "AAA"
def decsription = "test"
def leadkey = "102205"
def assigneeType = "Unassigned"
ProjectManager.updateProject(Project originalProject,Long name,String description,String leadKey,String url,Long assigneeType)
return:
The script could not be compiled:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
Script808.groovy: 10: The current scope already contains a variable of the name name
 @ line 10, column 59.
Script808.groovy: 10: The current scope already contains a variable of the name assigneeType
 @ line 10, column 114.
If i comment name and assigneetype i got: Cannot find matching mathod
Alexey Matveev
March 19, 2018
I did not check the code by it must be like this:
import com.atlassian.jira.project.AssigneeTypes
def originalproject = ComponentAccessor.getProjectManager().getPrjectObjByKey("TESTOR")
def name = "AAA"
def leadkey = "username"
ComponentAccessor.getProjectManager().updateProject(originalProject name,description,leadKey, url, AssigneeTypes.UNASSIGNED)
You should provide respect paramteres types.
Thanks! I still learning of groovy. I see that you have small mistake in def of original project. Should be "getProjectManager()" and must have:
"import com.atlassian.jira.component.ComponentAccessor" and "," before name in last line. Anyway. I used a code:
def originalproject = ComponentAccessor.getProjectManager().getProjectObjByKey("TESTOR")
def name = "AAA"
def leadkey = "102205" // this is username in my JIRA instance
ComponentAccessor.getProjectManager().updateProject(originalProject,name,description,leadKey,url,assigneeType.UNASSIGNED)
and after run i have:
groovy.lang.MissingPropertyException: No such property: originalProject for class: Script879
at Script879.run(Script879.groovy:12)
Compiler said:
any idea?
Alexey Matveev
March 19, 2018
Yes, the name of variable are different from declaration and passing the the procedure.
def name = "AAA"
def description = "test"
def url = "http://google.com"
ComponentAccessor.getProjectManager().updateProject(originalproject,name,description,leadkey,url,assigneeType.UNASSIGNED)
Ok. Foolishly mistakes in declaration... When i trying to use your code i have this:
groovy.lang.MissingPropertyException: No such property: assigneeType for class: Script885 at Script885.run(Script885.groovy:12)
so I change last line like this:
def assigneeType = "102205" as long
ComponentAccessor.getProjectManager().updateProject(originalproject,name,description,leadkey,url,assigneeType)
and Script working but in project i can see "Please select a Default Assignee". It looks that this method have problem with long "Unassigned"? Do you know something about this?
Alexey Matveev
March 19, 2018
def name = "AAA"
ComponentAccessor.getProjectManager().updateProject(originalproject,name,description,leadkey,url,AssigneeTypes.UNASSIGNED)
Thank you very much!
Tom March 3, 2020
I'm sorry to revive this thread, but I have a problem to set the lead.
In my case this is entered as text, but not as recognized user (AD). I have already tried different spelling variants.
What is the solution here?
Nitish Sajwan February 3, 2021
Hi Tom,
You might need to enter the userid instead of username.
Nitish
Tom February 4, 2021
Hello Nitish,
i have already solved my problem, but thanks for your advice.
https://community.atlassian.com/t5/Jira-questions/solved-Set-Project-Lead-with-Groovy-Script-Runner/qaq-p/1322400
