Setting a WIP limit colour
Colum McAndrew
September 3, 2021
We're on a company managed project, and have a WIP limit on our In Progress column. When the limit is reached, the column turns a dark shade of red. From an accessibility perspective, this isn't great and some of our users have commented on it.
It doesn't seem possible to set the WIP limit column colour in the same way as card colours. Is this correct, or am I missing something?
Jack Brickey
Correct this is not currently configurable. I was looking for a suggestion opened at jira.atlassian.com but did not find any such suggestion surprisingly. You might wish to click the Feedback button and provide that information to Atlassian.
Colum McAndrew
September 3, 2021
Many thanks Jack. Will do.
Andrés Capucho
November 24, 2023
However today (11/2023) the column color is light blue and for us the dark shadow of red would be better. Is it configurable nowadays?
Like Colum McAndrew likes this
Colum McAndrew
December 8, 2023
Hi @Andrés Capucho No it isn't :-(
Cindy Batte
August 20, 2024
Are there plans to make it configurable?
I use a WIP limit (column constraint) and the column did in fact turn RED at some point when limit was reached and now it does not. I would prefer it turning red when the WIP is over.
Yuri Lapin _Release Management_
December 1, 2021
Hi @Colum McAndrew
Trust you are well.
If you want to try out some Partner Apps our Advanced Agile Boards have a flexibility to define WIPs for individual columns, group of columns, swimlanes and their intersections plus give slightly bigger variety of options for color coding.
Yuri.
Colum McAndrew
December 1, 2021
Thank you Yuri.
