×Jira Data Center 9.0.0:
I am trying to setup our Jira workflow such that when we transition an issue to CLOSED, it has a transition screen prompting for the required RESOLUTION. However, if the RESOLUTION was picked to be FAILED, then we are wanting the user to be required to set a custom field with the KEY for the new issue that will follow up on the failed issue. (I know, we could just transition back the original issue to be re-worked but they don't want that. They want a new issue.)
Has anyone ever implemented such a transition to DONE or CLOSED where setting the RESOLUTION to a certain value that would further require the setting of another field to complete the transition.
We already have JSU Automation Suite for Jira Workflows. add-on.
Thanks.
Hi @Boyd K
Is it possible for you to create 2 transition, one for failed, one for passed then add a validator in the failed transition to set the field required using JSU ?
Regards
I was trying to make it happen with the one and same transition. But, if necessary, I could setup another transition and propose that to my team.
I don 't see how to do it with JSU only.
I know how to do it with Scriptrunner and porbably with JIRA Workflow Toolbox, but if you do not have this app I would go with multiple transitions.
Regards
