I'm working on a Jira automation rule where I'm trying to grab the assign the user to a task based on a task description. I first grab the substring from the description, and that substring contains the assignee display name as it appears in Jira. However, when I try to assign that string to the displayName attribute, nothing happens.
Could someone please help me work through this?
In the JSON box under "More options" in the rule configuration, I have the following right now:
"fields": {
"Assignee":[{"displayName":"{{issue.description.substringAfter("Assignee: ")}}"}]
You need to use the Atlassian ID for the assignee field, so you would have to use the web request component to send a request to either Get account IDs for users or find users and then get the ID from the result. Your JSON should look something like this:
{ "fields": { "assignee": { "id": "{{webhookData.accountId}}" } } }
I just want to give you a thumbs up, your reply re using the rest api to fetch user id helped out with my automation rule dilemma immensely !
Thank you
Trying to do similar by setting the trigger issue's assignee to the one found in branch jql (yes, will always find one).
{ "fields": { {{triggerIssue.assignee}} : { "id" : {{issue.assignee.accountId}} " } } }
is invalid JSON
I'm sure I'm fairly close but trying to get this to work on assignee seems different from custom fields which is usually the example and questions here.
@Marc Isikoff You cannot set the trigger issue's assignee in a branch, you can only edit the branch issue.
I would break that part out so you have two automations. The first one would do a web request to the second automation with the key to the trigger issue and the assignee that you want to set.
Actually you can and I just tested it:
Use standard automation (e.g., not branching) of edit issue, assign issue and use copy from another issue -> JQL Issue -> You JQL statement
