Setting jira.node.id Automatically
Jeff Shepherd
December 3, 2020
Is it possible to set the jira.node.id through a variable?
For example:
jira.node.id = ${HOSTNAME}
 Sadly, the above example doesn't work. My node id becomes the text "${HOSTNAME}"
Brant Schroeder
Jeff Shepherd
December 7, 2020
Ick. A solution, but not very elegant.
Tran Dien Hien September 26, 2021
@Jeff Shepherd ,
Have you solved this issue?  If yes please share your experiences because I'm facing the same problem.
I much appreciate your support
Jeff Shepherd
September 27, 2021
Referencing the above link, @Lessandro has a script to modify the cluster.properties before Jira is run (e.g. at reboot or via cron)
HOST=$HOSTNAME
JIRANODE="jira.node.id = "$HOST
sed -i "2s/.*/$JIRANODE/" /var/atlassian/application-data/jira/cluster.properties
The cluster.properties file only needs to be modified once, so a process that happens over and over seems a bit much.
However, I have a recipe I follow that includes a step to modify the file whenever I am adding a new Jira node. There are times I have overlooked the step in the past, so there is merit to an automated process.
