Dear Atlassian Community,
we are wondering if there is any possibility to restrict for some of our users to use QAlity Plus or if the whole users can access QAlity Plus?
Furthermore, can you give any selectable permissions to users? For example only view the issues but not update/create/delete them?
I am looking forward to hearing from you!
Thank you in advance.
With best regards,
Iris Studeny
Hi @Iris Studeny,
Nice to meet you! When it comes to QAlity Plus permissions, you can select things like:
You can read more about this in our documentation here.
We do not offer separate restrictions on who can edit Test Cases. Users who have Edit issues permission in the project settings can edit Test Steps as well.
Please feel free to contact us directly, through our service portal here. I will be happy to assist you.
Best regards,
Ewa
SolDevelo Team
Hello @Ewa Grabowska-Ptak_SolDevelo_ ,
thank you also for your reply and the feedback.
Then we will check and set the settings in the JIRA settings.
If we have any further questions we will come back to you!
Thank you!
With best regards,
Iris Studeny
Hi @Iris Studeny,
While not really familiar with this specific app, many times questions like this one are often asked to find out if there's a way to reduce the number of licensed users. That is usually not the case - apps are following the user tier of the Jira product they are added to.
A quick check of the documentation shows that the app can be enabled / disabled on a per project basis. While this is not user based, it may still be a way to take more granular control over who gets access to the app's features.
For more detailed information, it may be best to either dive into the app documentation or contact the app vendor directly. You can find both from the app's listing on the Altassian Marketplace.
Hope this helps!
Hello @Walter Buggenhout ,
thank you for your reply and the information.
We have already thought that this is the case.
If we need more information, then we will do so.
Thank you and have a nice week!
With best regards,
Iris Studeny
