Welcome to the community.
You will need to create an automation rule in Jira this rulle needs a trigger and optional a condition before the action (send web request)
@Marc - Devoteam It’s difficult for me to understand in which tab and what to create.
I'm completely confused.
Therefore, it would be more convenient for me to see a video tour from a screen recording
You already know where to be in Jira.
follow the above image to create the rule.
See this documentation
@Marc - Devoteam And what about CUSTOM smart values?
How to create, for example, "Name" setting, which would automatically put up a specific name?
Should a specific name be specified in the "Description"?
Or where?
See the manual you provided.
The text you want to specify on the telegram message needs to be specified in the Custom data field in the Send Web Request action.
Smart values for Jira description is:
{{issue.description}}
Name, depends on what you want top show, I usually use:
{{issue.reporter.displayName}}
See documentation on Smart Values
I would create a test issue (inform the members of the telegram channel you are executing tests first) and see if on the telegram channel the message is received.
Or create a test telegram channel in relation with a Jira test project and create a rule on this project.
This will help you on experimentation
How does the setup of your rule look like now?
@Marc - Devoteam May I know your E-mail address?
Or accept my request to connect on your «LinkedIn» network.
I'll post a video review.
It's better to see these mistakes once than to hear them a hundred times...
rnt73443@zslsz.com
I have not received it, are you able to sent it agian?
address: ruftmam77@gmail.com
I see you made a postman get call to Jira to a jira issue with key ISSUE-1, result does not exist.
Is there a issues in Jira with this key, I expect not.
Create an issue in your created project CRYSTALITE777, this will also trigger the automation you made.
See the log of the rule execution for details.
This will say CRYSTALITE-1 or other, do the same get in postman and replace ISSUE-1 with CRYSTALITE-1
This should then provide you with a result.
See what this all gives you and then we can move further.
I think you would benefit from this, free course to grasp the basics of Jira, before trying an integration with Telegram with automation.
This will explain you the concept on creating issues as I mentioned in my last comment with CRYSTALITE-1. And no the key is not a guess, as I saw your created project was named CRYSTALITE777 and the key of the project was CRYSTALITE.
So the first issue created in the project will have key: CRYSTALITE-1
The postman actions you showed in the video or the example url's used in the API doc's from Jira and don't mean this information is in Cloud instance upon creating one and, just making a project.
I hope the course will get you the basics and will help to use the automation you want to put in place.
