I am using a next-gen project.
I have noticed that all the settings/options for this project have disappeared. Furthermore, I am no longer able to add tasks directly to the kanban board in the edit-in-place/Trello-style.
What could be causing this?
Thanks for your help!
Hi Will,
Thank you for getting in touch with Atlassian Community!
Can you please click on "People" and check if you were added to the project?
When did this issue start? Have you checked if some other administrator has changed the access to the project?
Angélica
Hi Will,
This issue that you are facing was reported as a bug, but then the dev team said that it's expected because early created next-gen projects are not supported anymore. You can find their comment on the link below:
- https://jira.atlassian.com/browse/JSWCLOUD-17377
You will have to create a new project and move all the issues.
Angélica
OK, thanks!
I guess it's a bit odd that the people who were the earliest adopters of the new next-gen projects kinda get left in the dust... maybe they could have migrated automatically?
Anyway, I know what I need to do. Thanks for your help!
