Share RELEASE in one project with another project
Henry Kim
Literally, I wonder the versions in RELEASE(in left-side bar) can be shared with another project.
When I tried to make a ticket with fixed-version but seems like it cannot load the version info. from another project ( not linked between ). Is it available to link this between projects?
3 accepted
Trudy Claspill
Sharing releases across projects is supported by the Advanced Roadmaps feature which is available in the Jira Cloud Premium subscription, also.
Henry Kim
Yep, got it. thanks for the answer !
Like Martin Miller likes this
Jack Brickey
Hi Henry, Releases are per project unfortunately. You might see if there is some addon for cross project release management if that is an option.
Henry Kim
Okay I see! thank you :)
Yuri Lapin _Release Management_
November 15, 2021
Hi @Henry Kim
I hope this message finds you well.
One of the addons you might try out is Release Management & Roadmaps for Jira. We allow to group & manage releases (fix versions) for different project as cross-project release package. We also support versions sync for use cases when you actually need a single release across multiple projects.
Feel free to reach out our support team for a quick demo.
Yuri.
Henry Kim
Thanks for your kind answer!
Like Bob Brunk likes this
