Sharing filter with a project role I'm not part of using the REST API
Florian Bonniec
Hi
In JIRA Cloud I can share a filter with any role when I select a project and it worked just fine. With the REST API, if I share my filter with a role I'm part of, it works but I got an error when I try to share the filter with a role I'm not part of.
Do you have any workarount for this ?, Is this the expected behavior ? Sharing with the entire project works.
My payload is
"type": "projectRole",
"projectId": "10000",
"projectRoleId": "10002",
"rights": 1
When I'm part of role 10000 it works but as soon as I use another role it does not.
Regards
2 accepted
Vitalii Rybka
August 4, 2025
Hi @Florian Bonniec,
@Tomislav Tobijas is correct - this is expected behavior for security reasons. Here are a few workarounds:
Option 1: Service Account Approach
  • Create a dedicated service account with broader project role memberships
  • Use this account for filter sharing operations
  • Add it to all relevant project roles you need to share with
Option 2: Dynamic Role Management
  • Use REST API to temporarily add your account to the target role
  • Share the filter
  • Remove yourself from the role afterwards
  • /rest/api/3/project/{projectKey}/role/{roleId} endpoints
Option 3: Admin Privilege Escalation
  • If you're a Jira admin, you might need to make yourself the filter owner first
  • Transfer ownership back after sharing if needed
Option 4: Alternative Sharing Method
  • Share with entire project instead of specific roles
  • Use group-based sharing if your roles map to groups
  • Consider using dashboard sharing with embedded filters
API Sequence Example:
1. POST /rest/api/3/project/{projectKey}/role/{roleId} - Add yourself
2. PUT /rest/api/3/filter/{filterId}/permission - Share filter
3. DELETE /rest/api/3/project/{projectKey}/role/{roleId} - Remove yourself
The service account approach is cleanest for automation scenarios.
Need help implementing any of these patterns? Feel free to DM me!
Florian Bonniec
That’s what I was afraid of — it makes sense for it to behave that way through the API, but I was hoping for a cleaner workaround, since it doesn’t behave like that in the UI.
I think I will display the error to the end user, so he will add himself as role member if needed instead.
Regards
Like • Tomislav Tobijas likes this
Tomislav Tobijas
Hi @Florian Bonniec ,
I believe this is expected behavior—when sharing a filter with a project role via the REST API, you can only share it with roles that you are a member of in that project. This is 'by design' to ensure users can only share filters with the roles they have access to.
This limitation applies to end users and also Jira admins, unless you are the owner of the filter and a member of the target project role.
There's a relatively connected feature suggestion which you can take a look at: JRACLOUD-60899: As a Jira administrator I cannot view change the sharePermissions & editPermissions for private filters & private dashboards via REST API (not sure if there's a feature request directly connected with what you're looking for)
You could use REST API together with POST request to add yourself (or any other account you use for integration) to specific project role(s) within the project, and after that, make that API call related to the filter you need to update. đź‘€
Not sure if there are any other 'workarounds' you could use.
Tobi
FREE
