Description
I'm trying to run a simple script in post-function, and it seem seems to be running, but I'm not getting the field value updated. Am I missing something somewhere?
import java.sql.Timestamp
def userUtil = ComponentAccessor.getUserUtil()
def cfSeverity = customFieldManager.getCustomFieldObjectsByName("Severity")
def cfSeverityValue = issue.getCustomFieldValue(cfSeverity).toString()
int DueInDays = 0
log.warn ("Severity Value: "+ cfSeverityValue )
// Days in the future when the issue is due
switch (cfSeverityValue) {
case "Critical" : DueInDays = 30; break;
case "Major" : DueInDays = 60; break;
case "Moderate" : case "Minor" : DueInDays = 120; break;
default : DueInDays = 120; break;
// Make sure the due date doesn't fall on a weekend
Date today = new Date();
Calendar MyDueDate = Calendar.getInstance();
MyDueDate.add(Calendar.DATE,DueInDays)
while ([Calendar.SATURDAY, Calendar.SUNDAY].contains(MyDueDate.get(Calendar.DAY_OF_WEEK))) {
MyDueDate.add(Calendar.DATE,1)
def dueTimestamp = new Timestamp(MyDueDate.getTimeInMillis())
issue.setDueDate(dueTimestamp)
log.warn ("SetDueDate:" + dueTimestamp)
Workflow
Creates the issue originally.
Custom script post-function - Set Due Date based on Severity
Re-index an issue to keep indexes in sync with the database.
Fire a Generic Event event that can be processed by the listeners.
Execution
Time (on server): Thu Sep 24 2020 11:49:42 GMT-0400 (Eastern Daylight Time)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2020-09-24 11:49:42,861 WARN [runner.ScriptBindingsManager]: Severity Value: Major
2020-09-24 11:49:42,863 WARN [runner.ScriptBindingsManager]: SetDueDate:2020-11-23 11:49:42.863
Due Date is in Screen/Field Scheme for issue
Create Issue, Due date not filled manually
The field 'Due Date' does not have value for issue after Create.
Hi @Chris Cralle
You can move your script to the last position in your workflow and add this code :
import com.atlassian.jira.event.type.EventDispatchOption
//your code
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
IssueManager issueManager = ComponentAccessor.getIssueManager()
issueManager.updateIssue(user,issue,EventDispatchOption.DO_NOT_DISPATCH,false)
I hope this help you.
