I've added the Smart Checklists Add-on for JIRA Cloud, which seems to be installed (I can see it installed in the Manage Add-ons section).
I've created a new multi-line text field called Checklists as the instructions indicate, but when I input the checklist, it doesn't seem to show the formatted checklist.
Any thoughts on how to fix this?
The checklist is rendered on the right side.
See screenshot attached below.
It's a good idea to either
We will deliver "edit checklist" functionality in a next 3-6 weeks, so you won't have to keep the "Checklists" field on the "View Screen".
Makes sense ?
[IN-724] SUPPORT "Smart Checklists not formatting" - JIRA 2016-07-23 16-34-36.png
Hi Yaroslav,
Thanks, that makes sense and I do see it rendered in that view as your screen shot indicates. I was hoping to be able to see the rendered version in the Issue detail view of our Sprint board, since that is the view our team uses 95% of the time. Do you have plans to make it work in that view as well?
Nick
Hi Nick,
We've made a lot of improvements since the time you've asked your questions.
Check them here https://marketplace.atlassian.com/plugins/rw-smart-checklist-biz
Now add-on supports kanban, scrum board, issue detail and new issue view from an agile board.
Pavel Pavlovsky
Product Manager
