Smart Values in automation
Aditya Sastry
March 17, 2025
I've a ask to copy the component value to a custom label field on field change.
I've used {{issue.components.name}} for the same. However, I've spaces in between the component name and due to which the labels are created separately. I want to replace space with a character to avoid separate labels.
Any pointers?
Thanks in advance
Aditya
2 accepted
Vishal Biyani
March 17, 2025
@Aditya Sastry
Can you try using replaceAll(" ", "")?
{{issue.components.name.replaceAll(" ", "")}}
Aditya Sastry
March 17, 2025
Hi Vishal,
I've already tried it and it doesn't save. Maybe it is not a valid option.
Aditya
Vishal Biyani
March 17, 2025
Can you share the SS of your complete automation including how you are editing the field?
Aditya Sastry
March 17, 2025
I was able to get this to work with a global variable and used the variable to update my custom label field.
Pasam Venkateshwarrao
March 17, 2025
Hi @Aditya Sastry
Welcome to the community, while copying the Component values to the Labels list, it's possible to replace the space characters with another character using an "Additional Fields" custom script.
  1. Create your Automation Rule and configure the conditions to trigger the rule.
  2. Add an Edit issue action.Expand the drop-down list Choose fields to set... and select the Labels field.
    1. Add the script below to the Additional fields text field.
      { "fields":
      { "labels": {{issue.components.name.asJsonStringArray.replace(" ","-")}} }
    2. The Edit Issue action will look like this:
      edit issue action
Hope this helps
Aditya Sastry
March 17, 2025
Thanks Pasam for your response. It gave me a parsing error.
Error while parsing additional fields. Not valid JSON.
can you please help?
March 17, 2025
@Aditya Sastry have you used the same script
"fields": {
"labels":
Like Vishal Biyani likes this
