I've a ask to copy the component value to a custom label field on field change.
I've used {{issue.components.name}} for the same. However, I've spaces in between the component name and due to which the labels are created separately. I want to replace space with a character to avoid separate labels.
Any pointers?
Thanks in advance
Aditya
Hi Vishal,
I've already tried it and it doesn't save. Maybe it is not a valid option.
Aditya
Can you share the SS of your complete automation including how you are editing the field?
I was able to get this to work with a global variable and used the variable to update my custom label field.
Welcome to the community, while copying the Component values to the Labels list, it's possible to replace the space characters with another character using an "Additional Fields" custom script.
"fields":
"labels": {{issue.components.name.asJsonStringArray.replace(" ","-")}}
Thanks Pasam for your response. It gave me a parsing error.
Error while parsing additional fields. Not valid JSON.
can you please help?
@Aditya Sastry have you used the same script
"fields": {
"labels":
