Hi, I'm new in Jira Automation and I need your help.
When I want to copy from one user picker custom field to another (for example I want to copy 4 users to destination field) I put {{custom field.get(0)}} to destination custom field as a smart value, but when I want to put for example 6 values I have to put all six together in destination custom field as a smart value according ( {{custom field.get(0)}}, {{custom field.get(1)....... {{custom field.get(6)}} }} ). How Can I do this like this {{custom field.get(range)}}
Can you provide the whole scenario of what you're trying to achieve? This will help us visualise the issue better and help find a solution, if this remains a problem!
Ste
Hi @Ste Wright
Before coming to my question, another problem raised connected with custom field smart values. When I try to write in for example in the description or send Email with a valued user custom field {{issue."my custom field"_id}} automation Jira displays not user display name but displays user's account id.
Previously I was able to do that.
Have you checked out user properties for Smart Values?
It appears to suggest on this page you can use display name also.
Ste
