Smart value for Confluence content links in Jira Tickets
Jeanna Knowles
I am trying to create an automation for Jira, its mostly pretty basic.
I have a "template" jira issue that we are using.
My automation is:
Manually trigger
Then lookup issues > key=ABC-123
And create new Task
In the description box I have :
{{lookupIssues.description}}
This is working and pulling in the correct information.
However I have Confluence content links that I need to pull in as well. I can not figure out how to get this pulled in.
I have tried to set Confluence (Link) with a number of values and can not figure out what is the correct value. Currently I have {{lookupIssues.url}}
I have tried {{lookupIssues.contentlink}} and others. I have tried to plug them into the description field to see if I can get anything to pull in. I have been unsuccessful.
Any assistance would be appreciated.
2 accepted
Trudy Claspill
Hello @Jeanna Knowles
You could use a Send Web Request action to call the Jira REST API to retrieve the Remote Links for the template issue.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-remote-links/#api-rest-api-3-issue-issueidorkey-remotelink-get
You would have to parse the output to pull the Confluence links from it.
There is not an action in Automation to create a link to an existing Confluence page from a Jira issue. You would have to use Send Web Request again to call the API to create the link between the new issue and the Confluence content.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-remote-links/#api-rest-api-3-issue-issueidorkey-remotelink-post
If you've never worked with Send Web Request before, there is an article about it here:
https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Jeanna Knowles
Thank you, I will check it out.
Khira Niemeier
I have a similar problem and wanted to ask for help. :)
We are trying to set up an automation that clones a Ticket and also clones the Confluence Pages linked to the cloned Issue.
I didn't find out how I can get these links.
Could you maybe help me? My problem is I can't manage to get the right idea for the code, even after looking up the linked pages above.
Jeanna Knowles
@Khira Niemeier I never got this to work. Sorry
Like Khira Niemeier likes this
Khira Niemeier
@Trudy Claspill maybe you could help regarding this topic? :)
Bill Sheboy
October 15, 2024
Hi @Khira Niemeier
Trudy already described the solution in her first post: call the REST API endpoint to get the external links, using the Send Web Request action, and parse out the ones for Confluence.  I believe they appear with the relationship type of "wiki".
Luis Felipe Studzinski Santos July 19, 2024
@Jeanna Knowles
Unfortunately, there isn't a direct Smart Value specifically for Confluence content links. However, you can try to include the content link in a custom field or within the description of the template issue itself, which then can be referenced.
Jeanna Knowles
Thank you, I was thinking that might be the case.
