Smart value for not and equals operator not working
Amit Bansal
Team - I am trying to create an automation rule to print all sprint items however would like to ignore all issue types with status as "Cancelled" and "Invalid". Below is the query but it is not working. Any help would be greatly appreciated!
{{#lookupIssues}}
{{#if(not(equals(issue.status.name,"CANCELLED")))}}
{{issueType.name}} - <{{url}}|{{key}}> - _{{summary}}_ {{status.name}} is due on {{dueDate}}.
4 votes
Hana Kučerová
Hi @Amit Bansal ,
please try status (or status.name) instead of issue.status.name in the condition.
See here for more info:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
Hana Kučerová
Hi @Amit Bansal ,
I've just tested it and it works for me:
{{#lookupIssues}}
{{#if(not(equals(status.name,"New")))}}
{{status.name}}
The problem could be in the status name - CANCELLED is not the same as Cancelled. So if your status is called Cancelled (not CANCELLED), your condition won't work.
Maybe it will be the best to use status.id in the condition instead of name.
Amit Bansal
It worked. Thank you so much.
Amit Bansal
Hana - While I am trying to use "and" operator, it is giving me an error (row 2). Would be of big help if you know the fix.
{{#lookupIssues}}
{{#if(not(equals(and(status.name,"Cancelled"),(status.name,"Invalid"))))}}
Amit
Hana Kučerová
Hi @Amit Bansal ,
please try:
{{#if(and(not(equals(status.name,"Cancelled")),not(equals(status.name,"Invalid"))))}}
Like Bill Sheboy likes this
Amit Bansal
It worked...Thanks a ton.
Like Hana Kučerová likes this
Amit Bansal
Thanks Hana....Tried it too earlier but it also did not work.
