Hi Community,
I’ve set up an automation rule in Jira Cloud to copy labels from a parent issue to a newly created subtask. I'm using the smart value {{issue.parent.labels}}
, selected from the suggested smart values in the automation editor.
What I expect:
When a subtask is created, it should inherit the labels from its parent (e.g., "Priority").
What actually happens:
Instead of applying the label, Jira sets the subtask’s label field to the literal string {{issue.parent.labels}}
. The smart value isn't being evaluated — it's just treated as plain text.
What I’ve tried:
Selected the smart value via the dropdown (not typed manually)
Ensured the parent has labels
Verified rule scope includes both parent and subtask
Tried both in the standard Edit Issue action and also in smart value mode
Confirmed this is not a permissions issue
Anyone else encountered this? Is this expected behavior?
Thanks in advance.
Hi @Sajjad Ali , definitely understand the weird behavior here! The smart value, will generally dump things out as text. You can get around this, though, by copying the field values instead. This would look something like:
The key here, is to set "copy from" to "parent work item" - also probably a good idea to check the "add to existing values" box in case there are other labels auto-created.
Give that a try and see if that works for your use-case!
Hello @Sajjad Ali
in this case you are not using the smart value but setting the string "{{smartvalue.parent.labels}}".
The easiest way to solve this would be to copy the settings rom the parent instand of setting them via a smart value.
To do that just edit your action in the last photo via the three little dots and choose copy. Then you can choose parent as the source.
BR,
Jan
