Smart values: access an issue sprints
Raffaele Litto March 11, 2021
How can I access a list of an issue sprints with smart values?
Looking at Smart values I cannot find a reference to it
Bill Sheboy
March 11, 2021
Hi @Raffaele Litto
Have you tried {{issue.sprint}} yet?  That is a list of the sprints an issue has been assigned to and which have at least started.
Here is the documentation on the value to see what is available within it:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-general/#Smartvalues-general-{{Sprint}}
And here is information on working with list smart values:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-lists/
Best regards,
Raffaele Litto March 12, 2021
so it exists? it wasn't documented. is it {{issue.sprint}} or {{issue.sprints}}?
I suppose that would work. But then finding if the sprint the issue is now is closed that would be a different matter.
For the moment as a workaround I looked at the issue status, assuming that if all sprints are closed the issue is in a closed state (bit risky in some edge cases I know)
Bill Sheboy
March 15, 2021
It is {{issue.sprint}}  singular.
For closure detection, you may check {{issue.sprint.state}} for "closed"
Or, you may use JQL: sprint IN closedSprints()
Like # people like this
Raffaele Litto March 15, 2021
Thanks!
Ravi Sagar _Sparxsys_
March 11, 2021
Hi @Raffaele Litto
You can use the standard smart value to get the issue fields.
{{issue.fields.customfield_XXXXX}}
You can use this REST end point "JIRAURL/rest/api/latest/field" to find the Sprint field's customfield id.
I hope it helps.
Ravi
