Some of my custom field values are not showing while creating task
Naveen Pendly August 18, 2022
My custom field have 40 values, in that some are not showing , we don't have any special context also
Trudy Claspill
@Naveen Pendly
Can you provide a screen image to clarify the problem you are seeing?
What type of field is it?
select list(single choice)
Trudy Claspill
Is this for a Team Managed project or a Company Managed project?
It's datacenter, while creating issue field value of task type-pse(Cert- Beta Testing) not appearing
Trudy Claspill
If you start typing into the field "Cert" does that reduce the list to display matching entries and include the entry you want?
@Trudy Claspill Attached images
@Trudy Claspill No, it's not working
Trudy Claspill
Can you provide a screen image of what happens when you start typing in the value you want?
can we have quick call on this?
Trudy Claspill
No, I'm sorry, but we cannot. I am just another Jira user trying to offer assistance as my time allows.
If you would like more official technical support with the Jira product, you may want to open a case directly with Atlassian Support.
https://support.atlassian.com/contact/#/
