I'm a Jira Administrator on a Jira Software 8.0.2 using Server License, but for the last couple of months I've been unable to delete empty Jira Release versions from Jira project.
There are no issues assigned or affected by these versions, but when I try to delete it, a spinning wheel appears that remains stuck even for hours. If I refresh the page, the delete action is not taken and the version remains.
Steps:
in 95% of cases this is the behavior when trying to delete the version. in the remaining 5% of cases I am able to delete the same version in the same project without any issue instantaneously.
Any clues why this is happening ? Any workaround is highly appreciated.
Thank you!
Hi Mihaela,
I'm having the same issue. Did you solve it?
We faced the same problem. But we found out that this is a known bug in Jira.
https://jira.atlassian.com/browse/JRASERVER-67198
They provide a work around solution to this problem.
For more details, please contact the Atlassian team for this issue.
Thanks!
Thanks Hareesh,
I have raised them a ticket this morning so I'll let you know what they say.
