Startup check failed. Jira will be locked
geoffbland January 20, 2022
I am running Jira 8.20.3 running on Ubuntu Server 20.04 against a MySQL database, OpenJDK Java 11. All was working fine until the server restarted last night, from the logs a small Ubuntu patch was applied last night and the server rebooted. This patch is probably unrelated but after the reboot the server will locks on start up.
I am getting the "Startup check failed. Jira will be locked" error:
2022-01-20 18:49:11,669+0000 JIRA-Bootstrap FATAL [c.a.jira.startup.JiraStartupLogger] Startup check failed. Jira will be locked.
I have check no other instance is running. I have tried removing the /var/atlassian/application-data/jira/.jira-home.lock file but JIRA server still will not start up.
No other errors or warnings are shown in the catalina.log. What should I look at next to resolve this?
Full start-up catalina.log:
NOTE: Picked up JDK_JAVA_OPTIONS: --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
20-Jan-2022 18:49:07.205 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/8.5.65
20-Jan-2022 18:49:07.208 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Mar 30 2021 12:28:40 UTC
20-Jan-2022 18:49:07.208 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 8.5.65.0
20-Jan-2022 18:49:07.208 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
20-Jan-2022 18:49:07.208 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 5.4.0-96-generic
20-Jan-2022 18:49:07.210 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
20-Jan-2022 18:49:07.210 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /opt/atlassian/jira/jre
20-Jan-2022 18:49:07.210 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 11.0.11+9
20-Jan-2022 18:49:07.210 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: AdoptOpenJDK
20-Jan-2022 18:49:07.210 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /opt/atlassian/jira
20-Jan-2022 18:49:07.210 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /opt/atlassian/jira
20-Jan-2022 18:49:07.211 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
20-Jan-2022 18:49:07.211 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
20-Jan-2022 18:49:07.211 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
20-Jan-2022 18:49:07.211 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/opt/atlassian/jira/conf/logging.properties
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms384m
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
20-Jan-2022 18:49:07.212 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.plugins.startup.options=
20-Jan-2022 18:49:07.213 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
20-Jan-2022 18:49:07.213 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
20-Jan-2022 18:49:07.213 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
20-Jan-2022 18:49:07.213 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xlog:gc*:file=/opt/atlassian/jira/logs/atlassian-jira-gc-%t.log:tags,time,uptime,level:filecount=5,filesize=20M
20-Jan-2022 18:49:07.213 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+ExplicitGCInvokesConcurrent
20-Jan-2022 18:49:07.215 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
20-Jan-2022 18:49:07.216 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/opt/atlassian/jira
20-Jan-2022 18:49:07.216 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/opt/atlassian/jira
20-Jan-2022 18:49:07.217 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/opt/atlassian/jira/temp
20-Jan-2022 18:49:07.217 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib]
20-Jan-2022 18:49:07.491 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
20-Jan-2022 18:49:07.564 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 964 ms
20-Jan-2022 18:49:07.602 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
20-Jan-2022 18:49:07.602 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/8.5.65]
2022-01-20 18:49:11,003+0000 localhost-startStop-1 INFO [c.a.jira.startup.JiraHomeStartupCheck] The jira.home directory '/var/atlassian/application-data/jira' is validated and locked for exclusive use by this instance.
2022-01-20 18:49:11,097+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Jira starting...
2022-01-20 18:49:11,197+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 8.20.3#820003-sha1:e9c1f3b400a5545d56ec3d8e0414de7a0e75ddb3
Build Date : Thu Dec 16 00:00:00 UTC 2021
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/8.5.65 - Servlet API 3.1
Java Version : 11.0.11 - AdoptOpenJDK
Current Working Directory : /
Maximum Allowable Memory : 2048MB
Total Memory : 384MB
Free Memory : 140MB
Used Memory : 244MB
Memory Pool: CodeHeap 'non-nmethods' : CodeHeap 'non-nmethods': init = 5832704(5696K) used = 1173888(1146K) committed = 5832704(5696K) max = 5832704(5696K)
Memory Pool: Metaspace : Metaspace: init = 0(0K) used = 28642792(27971K) committed = 29671424(28976K) max = -1(-1K)
Memory Pool: CodeHeap 'profiled nmethods' : CodeHeap 'profiled nmethods': init = 33554432(32768K) used = 9038336(8826K) committed = 33554432(32768K) max = 265519104(259296K)
Memory Pool: Compressed Class Space : Compressed Class Space: init = 0(0K) used = 3143616(3069K) committed = 3538944(3456K) max = 1073741824(1048576K)
Memory Pool: G1 Eden Space : G1 Eden Space: init = 20971520(20480K) used = 217055232(211968K) committed = 238026752(232448K) max = -1(-1K)
Memory Pool: G1 Old Gen : G1 Old Gen: init = 381681664(372736K) used = 23196928(22653K) committed = 148897792(145408K) max = 2147483648(2097152K)
Memory Pool: G1 Survivor Space : G1 Survivor Space: init = 0(0K) used = 15728640(15360K) committed = 15728640(15360K) max = -1(-1K)
Memory Pool: CodeHeap 'non-profiled nmethods' : CodeHeap 'non-profiled nmethods': init = 33554432(32768K) used = 2831104(2764K) committed = 33554432(32768K) max = 265519104(259296K)
JVM Input Arguments : --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED -Djava.util.logging.config.file=/opt/atlassian/jira/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Xms384m -Xmx2048m -XX:InitialCodeCacheSize=32m -XX:ReservedCodeCacheSize=512m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -XX:-OmitStackTraceInFastThrow -Djava.locale.providers=COMPAT -Datlassian.plugins.startup.options= -Djdk.tls.ephemeralDHKeySize=2048 -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -Xlog:gc*:file=/opt/atlassian/jira/logs/atlassian-jira-gc-%t.log:tags,time,uptime,level:filecount=5,filesize=20M -XX:+ExplicitGCInvokesConcurrent -Dignore.endorsed.dirs= -Dcatalina.base=/opt/atlassian/jira -Dcatalina.home=/opt/atlassian/jira -Djava.io.tmpdir=/opt/atlassian/jira/temp
Java Compatibility Information : JIRA version = 8.20.3, Java Version = 11.0.11
___ Java System Properties _________________
atlassian.plugins.startup.options :
atlassian.standalone : JIRA
awt.toolkit : sun.awt.X11.XToolkit
catalina.base : /opt/atlassian/jira
catalina.home : /opt/atlassian/jira
catalina.useNaming : true
common.loader : "${catalina.base}/lib",
"${catalina.base}/lib/*.jar",
"${catalina.home}/lib",
"${catalina.home}/lib/*.jar"
file.encoding : UTF-8
ignore.endorsed.dirs :
java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.print.PSPrinterJob
java.class.version : 55.0
java.home : /opt/atlassian/jira/jre
java.io.tmpdir : /opt/atlassian/jira/temp
java.locale.providers : COMPAT
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.protocol.handler.pkgs : org.apache.catalina.webresources
java.runtime.name : OpenJDK Runtime Environment
java.runtime.version : 11.0.11+9
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 11
java.util.logging.config.file : /opt/atlassian/jira/conf/logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : AdoptOpenJDK
java.vendor.url : https://adoptopenjdk.net/
java.vendor.url.bug : https://github.com/AdoptOpenJDK/openjdk-support/issues
java.vendor.version : AdoptOpenJDK-11.0.11+9
java.version : 11.0.11
java.version.date : 2021-04-20
java.vm.compressedOopsMode : 32-bit
java.vm.info : mixed mode
java.vm.name : OpenJDK 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 11
java.vm.vendor : AdoptOpenJDK
java.vm.version : 11.0.11+9
jdk.debug : release
jdk.tls.ephemeralDHKeySize : 2048
mail.mime.decodeparameters : true
org.apache.catalina.security.SecurityListener.UMASK : 0027
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
os.arch : amd64
os.name : Linux
os.version : 5.4.0-96-generic
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : /opt/atlassian/jira/jre/lib
sun.cpu.endian : little
sun.cpu.isalist :
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level : unknown
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.StandardJarScanFilter.jarsToScan : log4j-taglib*.jar,
log4j-web*.jar,
log4javascript*.jar,
slf4j-taglib*.jar
tomcat.util.scan.StandardJarScanFilter.jarsToSkip : annotations-api.jar,
ant-junit*.jar,
ant-launcher.jar,
ant.jar,
asm-*.jar,
aspectj*.jar,
bootstrap.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-jmx-remote.jar,
catalina-storeconfig.jar,
catalina-tribes.jar,
catalina-ws.jar,
catalina.jar,
cglib-*.jar,
cobertura-*.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-daemon.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
dom4j-*.jar,
easymock-*.jar,
ecj-*.jar,
el-api.jar,
geronimo-spec-jaxrpc*.jar,
h2*.jar,
hamcrest-*.jar,
hibernate*.jar,
httpclient*.jar,
icu4j-*.jar,
jasper-el.jar,
jasper.jar,
jaspic-api.jar,
jaxb-*.jar,
jaxen-*.jar,
jdom-*.jar,
jetty-*.jar,
jmx-tools.jar,
jmx.jar,
jsp-api.jar,
jstl.jar,
jta*.jar,
junit-*.jar,
junit.jar,
log4j*.jar,
mail*.jar,
objenesis-*.jar,
oraclepki.jar,
oro-*.jar,
servlet-api-*.jar,
servlet-api.jar,
slf4j*.jar,
taglibs-standard-spec-*.jar,
tagsoup-*.jar,
tomcat-api.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-i18n-*.jar,
tomcat-jdbc.jar,
tomcat-jni.jar,
tomcat-juli-adapters.jar,
tomcat-juli.jar,
tomcat-util-scan.jar,
tomcat-util.jar,
tomcat-websocket.jar,
tools.jar,
websocket-api.jar,
wsdl4j*.jar,
xercesImpl.jar,
xml-apis.jar,
xmlParserAPIs-*.jar,
xmlParserAPIs.jar,
xom-*.jar
user.country : GB
user.dir : /
user.home : /home/jira
user.language : en
user.name : jira
user.timezone : Etc/UTC
20-Jan-2022 18:49:11.252 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
20-Jan-2022 18:49:11.260 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
20-Jan-2022 18:49:11.273 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 3707 ms
2022-01-20 18:49:11,351+0000 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/dbconfig.xml
2022-01-20 18:49:11,376+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
2022-01-20 18:49:11,377+0000 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
2022-01-20 18:49:11,668+0000 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks.
2022-01-20 18:49:11,715+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Startup is complete. Jira is ready to serve.
2022-01-20 18:49:11,717+0000 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 55 MiB. Committed: 384 MiB. Max: 2048 MiB
Non-heap memory : Used: 53 MiB. Committed: 110 MiB. Max: 1536 MiB
TOTAL : Used: 107 MiB. Committed: 494 MiB. Max: 3584 MiB
geoffbland January 23, 2022
Answering my own issue here.
The issue was that the MySQL database jira user had lost access rights to the jira database. Re-assigning access rights and restarting the jira service fixed the issue.
Why are there no warnings in the logs that the problem is that the database is not accessible?
Paul Pelland
February 6, 2023
I have same issue.  Where did you get access rights info?  (thanks)
