Hey all,
I'm racking my brain and I've scoured the help here to no avail - I cannot determine how to get fields from a parent to a sub-task as part of automation.
I have an "On Issue Created" automation that I want to create a number of sub-tasks. This issue type I have limited for the automation has a number of custom fields associated with it. As an example, one of these is "Employee Full Name".
I've tried *ALL* of the following to try to get that field as a variable into the sub-task generator, and all of them show up blank. What am I doing wrong??
# {{Employee Full Name}}
# {{Employee Full Name.value}}
# {{"Employee Full Name"}}
# {{"Employee Full Name".value}}
*fields.*
# {{fields.Employee Full Name}}
# {{fields.Employee Full Name.value}}
# {{fields."Employee Full Name"}}
# {{fields."Employee Full Name".value}}
*issue.*
# {{issue.Employee Full Name}}
# {{issue.Employee Full Name.value}}
# {{issue."Employee Full Name"}}
# {{issue."Employee Full Name".value}}
*issue.fields.*
# {{issue.fields.Employee Full Name}}
# {{issue.fields.Employee Full Name.value}}
# {{issue.fields."Employee Full Name"}}
# {{issue.fields."Employee Full Name".value}}
*issue.parent.*
# {{issue.parent.Employee Full Name}}
# {{issue.parent.Employee Full Name.value}}
# {{issue.parent."Employee Full Name"}}
# {{issue.parent."Employee Full Name".value}}
*issue.parent.fields.*
# {{issue.parent.fields.Employee Full Name}}
# {{issue.parent.fields.Employee Full Name.value}}
# {{issue.parent.fields."Employee Full Name"}}
# {{issue.parent.fields."Employee Full Name".value}}
*parent.*
# {{parent.Employee Full Name}}
# {{parent.Employee Full Name.value}}
# {{parent."Employee Full Name"}}
# {{parent."Employee Full Name".value}}
*parent.fields.*
# {{parent.fields.Employee Full Name}}
# {{parent.fields.Employee Full Name.value}}
# {{parent.fields."Employee Full Name"}}
# {{parent.fields."Employee Full Name".value}}
I am unclear about some of the extra characters in what you posted, and...
Smart values are case-sensitive, so I suggest finding an example issue with your field filled in, and then try the instructions in this how-to article to confirm the smart value name. Basically, you call the REST API from a browser and then search for your field name and the data contents to confirm the name.
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
For some automation syntax, you will still need to use the custom field ID rather than the name, so this technique will also find that information.
Best regards,
Thanks, Bill - I expected those to work, too, and they did not. I've double and triple checked the case; unfortunately, no dice.
I'll double-check the API in the morning, but the characters I posted was basically an example of me banging my head against the wall as I tried everything I could think of (including looking up the smart values). Will accept the answer or write back in the morning - thanks!
