Subversion Integration for Jira - is there a similar product for Cloud?
Endre Kallai
Hi guys,
One of our devs said he'd worked on a project in Jira that has updated Jira issues using this plug-in automatically.
Is there any plug-ins that would work the same way for a Next-Gen project in Jira Cloud at all?
Also, how can you find out which version of product you're using, please?
Thank you so much,
Endre
Nic Brough -Adaptavist-
November 16, 2020
See https://marketplace.atlassian.com/search?hosting=cloud&query=subversion
For the version of the product you are on, you can use the REST API to extract the build number from Cloud, but I doubt you'll find any use for it.  Why are you asking?
Endre Kallai
One of our devs has said it would automatically update Jira issues in the workflow. I don't really know these plugins hence I'm asking. You think it wouldn't make a difference?
