Hi all,
I have the following problem, for some reason the Summary field (a non optional field) appears without the * character, and for integrations with Zoom now I have problems because that field (the principal field of the ticket) is missing.
Do you know how could it be solved?
Hi Samuel - Welcome to the Atlassian Community!
What type of project is this? If Company-managed, check the Field Configuration for that project and issue type for the Summary field to see what it says.
Well it says team-managed project but I actually have no access to the Field Configuration. I only know that Summary should be a non negotiable field.
Other than this, I actually don't know how to make it clear to report this issue with my Jira Administrators, I seem uncapable of configure this field Summary.
Do you know if there's an inner configuration that I can report?
Thanks for your help.
Best regards.
Hi @John Funk
I've been doing a little more research but not finding any solution yet. All I got this far is that the Field Configuration (at least in de administraition panel in this temporary new server for testing) shows which fields are a Must, but still not getting why this field changed in the real one.
I'm still checking if I get something else where it may fails but, not success yet.
I would appreciate your commentaries.
Regards.
Sorry for the delay. Yes, Team-managed are different and totally independent from the shared Field Configuration files where you would normally resolve this.
I would say this is clearly a bug. If this is a new issue type on this project, you might just try deleting it and starting the process again.
Otherwise, you will probably need to open a support ticket with Atlassian to find out what happened. If you do that, please post the resolution back here - I would love to know what happened.
Hi @John Funk
I've reported it several time ago, but it was about yesterday or two days ago when I've seen the change applied in the configuration.
Now it's working properly, I imagine they changed the field configuration inside the "system".
I haven't heard from Atlassian about the issue but if I get anything that enlights this up I'd share it here.
Thanks for the support.
Regards.
same old "never be seen again solution" ahh answer
