Hello everyone!
I am trying to upgrade our JIRA instance from version 7.4 to 8.1. When I try to run the installation wizard and choose Upgrade an existing JIRA installation it shows that i have an existing JIRA installation directory, but it points to a wrong directory(in fact to a directory that doesn't even exist). Funny thing is that when i choose Custom or Express install, it points to a correct installation directory and when i select it, it says JIRA is already installed there.
I can't change the installation directory either.
What might be the issue and how can i resolve this? This situation is critical and fast feedback is greatly appreciated.
Thank you in advance.
The solution to this problem was running the installation wizard without sudo command.
Hi @Matis Aas ,
Fast workaround to create link form 'what want installer' to right directory.
Maybe some variable in scripts? Check scripts in bin directory.
grep -ne "dir which found installer" /Atlassian/JIRA7/bin*
B.R.
Hello Andrei!
Thank you for your reply, but this isn't the case. I grepped the directory, but it isn't defined anywhere. I am sure there's a simple fix, but I can't seem to locate it.
Matis
