TM4J: How to move test cycles from one project to another.
Arpine Aleksanyan
June 22, 2020
I have an old project with test cycles in it. I was able to move test cases, but didn't find a way for test cycles. Is there any way to move or clone test cycles from one project to another.
Armi Shayne Macatangay
December 1, 2020
Hi.. Is there any update for this issue as we are in the same situation where we want the test cycles to be reusable for multiple projects in Zephyr Scale (formerly known as TM4J)?
asadiq
I have the similar issue. It would be nice to get the solution.
asadiq
Hi Armi
I think there is no way to export the test cycles. However, you can export and import the test cases.
Steps to move the test cases.
Step1: Export the test cases from the old project
Step2: Import the test cases into new project.
Step3: Make new test cycles out of these newly imported test cases.
What would happen to my test cycle reports?
You can easily generate the test cycle reports in the old project by following the below steps.
1) Navigate to the old project
2) Click on Zephyr
3) click on Reports
4) select the report that you want to generate
5) View, Save, or print the cycle test reports as you like.
