Tables in JIRA DB containing the project id and schemes associated with it
mohit mathur June 4, 2015
I want to create a list containing projects, issue types associated with that projects and schemes associated with that projects. I was looking for a table in JIRA DB which contains a relation between projects and schemes associated with it.
Is there any table in JIRA DB containing projects id and schemes associated with it ?
Nic Brough -Adaptavist-
June 4, 2015
Try nodeassociation - that holds some of the scheme relations.
Maciej Olszewski
that was a droid i was looking for!
Chander Inguva
June 4, 2015
Hi mohit,
  • There is no direct table which has project ids and schemes associated with it.
  • You can create a list containing projects and their issue types
    select * from jiraissue where PROJECT=<Project_ID> AND issuetype=<Issuetype ID>;
  • To get the Project ID and Issuetype ID you have to look into project and issuetype tables respectively.
  • This gives all the issues of that particular Project and corresponding issue type associated with the Project
Regards
Chander Inguva
Is there any way to find the projects and the schemes(i.e workflow scheme, issue type screen scheme, field configuration scheme ) associated with that project.
June 4, 2015
Look in nodeassociation. It's better that we don't hand it to you on a plate, because having a look is the best way to learn and understand it.
MattS
June 5, 2015
I'd probably use Script Runner and google. https://answers.atlassian.com/questions/11146/how-to-look-at-issue-type-in-condition-section-of-script-post-function-function-for-a-transition is the first hit with comments from Jamie but there are a few others
