I just created a new Business Project in Jira Cloud. I can create 2 types of tasks: Task and Subtask.
1. When I create a Task, I cannot see a capability how to create a Subtask of that task
2. I can create a Subtask, but there is no capability to indicate which is the Parent task of that Subtask.
Hi @Kako Kvantaliani ,
You will not be able to create a subtask without the parent issue. If you are creating an Issue by clicking the create button (+)then it will be standard issue type (Task).
Please go through the Configuring sub-tasks page from more information.
Kishore
@[deleted]
I have 2 types of Subtasks: Subtask and Sub-task.
When I use Software Project template it acts as you mentioned. There are Sub-Tasks, not Subtasks. But in case of Business Project template when pressed (Create) I can choose either Task or Subtask.
Resolved. Jira Settings - >Issue type schemes - >removed Subtask type from Business Project and repaced with Sub-Task.
Great. You have created a "subtask" has a standard issue type that is the reason, you are able to create an issue with subtask issue type.
Kishore
@[deleted] ,
Actually, this Subtask type was inherited from the template. The Business Project template should be corrected by Jira service team.
@Kako Kvantaliani , yes, we had the same case with the template. Like you told the resolution is Jira Settings - >Issue type schemes - >removed Subtask type from Business Project and repaced with Sub-Task.
