Team dashboard- need unique (per project) column headers when click though to the issue navigator
Josh Shelton September 6, 2019
Our marketing Dashboard has gadgets that point to multiple project and issues. For example, I have a pie chart that allows me to look at unresolved issues and another that points to issues that are used to track the repair process flow. If I click through my pie chart gadget to view a specific group of issues in one project the same column headers are shown when I look at another project issue navigator screen. The headers only make sense for the one project...
Can you please assist?
Earl McCutcheon
September 9, 2019
Hi Josh,
There is not an option to add in additional details on the popup but a simple fix would be to rename the pie chart and add the project name to the Pie chart title:
Screen Shot 2019-09-09 at 2.49.25 PM.pngScreen Shot 2019-09-09 at 2.49.48 PM.png
Earl
Josh Shelton September 9, 2019
Hi Earl,
I may have been unclear, I am not looking to add anything to the pop up, I am wanting to have the column fields (once you click through) reflect the important info in that project. Currently "my defaults" column view work well for some projects but I have to adjust them to see the important info in other projects...
I can send other screen shots if needed.
