Test results under test case are not showing under Execution tab
sthumulati April 20, 2021
Under my Jira project using REST API calls
1) Created a test case
2) Attempted to create a test result
3) Clicked the test case name
4) Clicked the Execution(s) tab
Result: No Results showing
Jarosław Solecki _Deviniti_
Hi @sthumulati ,
are you using Requirements and Test Management for Jira or some other application?
sthumulati April 21, 2021
I apologize for not mentioning. Zephyr Scale or TM4J.
Are there any permissions I need to set?
sthumulati May 1, 2021
I haven’t gotten a reply. Please help!
@sthumulati  It would be best if you write directly to the plugin vendor.
You can find contact information at the app listing at Atlassian Marketplace in the "Support" tab.
SERVER
