I want to make a button with a webitem and show the vm file with a webwork when the button is pressed. However, there seems to be a size limit when showing VM files. And I think the VM file contains elements that I didn't define. Please help me.
now :
i want :
VM file code :
<section
id="static-dialog"
class="aui-dialog2 aui-dialog2-large"
role="dialog"
tabindex="-1"
aria-labelledby="static-dialog--heading"
<header class="aui-dialog2-header">
<h1 class="aui-dialog2-header-main" id="static-dialog--heading">목표일자 변경 승인요청</h1>
</header>
<!-- Main dialog content -->
<div class="aui-dialog2-content">
<form class="aui">
<div class="field-group">
<label for="text-input">변경될 목표 일자<span class="aui-icon icon-required">required</span></label>
$webResourceManager.requireResourcesForContext("approval")
<input class="aui-date-picker" id="demo-range-1" type="date" max="2012-01-25" min="2011-12-25" />
</div>
<label for="disabled-field-id">승인자<span class="aui-icon icon-required">required</span></label>
<input class="text" type="text" id="disabled-field-id" name="nameoffield" disabled>
</div>
<label for="textarea-id">변경 사유</label>
<textarea class="textarea" name="change" id="textarea-id"></textarea>
</div>
</form>
</div>
<!-- Dialog footer -->
<footer class="aui-dialog2-footer">
<!-- Actions to render on the right of the footer -->
<div class="aui-dialog2-footer-actions">
<button class="aui-button aui-button-primary">결재요청</button>
<button class="aui-button">취소</button>
</div>
</footer>
</section>
Hi
Have you seen this page https://aui.atlassian.com/aui/8.5/docs/dialog2.html
It explains about possible "sizes" for the dialog. It is probably not a good idea to have anything custom, just pick the option that fits your scenario
In the first example they have it looks very similar to what you want to achieve
Hope it helps
Alex
