Though I am setting transition rule, it's not working as expected, i.e. I have created a rule for transition "in PR" to "In QA". Where I used 1. rule: Restrict to when a field is a specific value 2. For this field=Assignee 3. Review it's value as Text 4. Check if it=Equal 5. This value= "Mafatlal" With above schenario, I checked issue to move from status "IN PR" to "IN QA", not changing assignee, it's not ristricting nor giving any message. Could you please help me with this. I am sharing some screenshots for your reference
Please share screenshots.
In the audit log, do you see the conditions getting passed for the execution?
Ah sorry, the screenshots didnt load earlier and i assumed this was 'Automation' rule.
I see now that you are using the new workflow editor and set a 'Condition' on the transition.
I do not have the 'Restrict to when a field is in specific value' restriction in my site but i added the below after switching to the old editor view and works well for me as defined.
