Time out error when click on some issues move to bottom of backlog.
Mandia July 8, 2018
I'm selecting about 20-30 issues in backlog, click on Move to Bottom of Backlog, and get timed out error.
Earl McCutcheon
July 9, 2018
Hello Mandia,
There are a few things to check out.
First look at the atlassian-jira.log and the atlassian-greenhopper.log to see if there are any explicit stack trace errors that can give some additional info on the cause of the timeout error.
Next Run the LexoRank management console Integrity checks as covered in This Article to see if there are any integrity issues identified,  as well as run the troubleshooting steeps covered In This KB especially the max rank length SQL query to see if the rebalance operations are completing successfully:
SELECT "FIELD_ID", max(length("RANK")) AS max_rank_string_length FROM "AO_60DB71_LEXORANK" GROUP BY "FIELD_ID";
Earl
Mandia July 10, 2018
Thanks for reply me.
The root cause of this issue is that I select too many issues.
Mandia
