To develop status tracker for dashboard using filter as shown in image ,which plugin should i use
jeetu May 9, 2017
Nic Brough -Adaptavist-
May 9, 2017
It is impossible to know.  You have not told us
  • which Atlassian application you are building for,
  • whether the aim is to track it in that application and publish this thing, or draw the tracker into the application
jeetu May 9, 2017
  • I want to develop it on jira to dsipaly it on dashboard
  • I want to track status of issues using the above diagram ,phases like order placed ,prep ,bake should be replaced by design,development,etc
  • i want to track status in jira and publish there
  • i have developed filter to track status ,
  • in which plugin should i use the filter to publish in above mentioned format
