I install Jira on CentOs machine when I try to run ./startup.sh I got this error , How can I fix this error,
jiracodeplait@jira.codeplait.net [/opt/atlassian/jira/bin]# sudo ./startup.sh
`sMMMMMMMMMMMMMM+
MMMMMMMMMMMMMM
:sdMMMMMMMMMMM
MMMMMM
`sMMMMMMMMMMMMMM+ MMMMMM
MMMMMMMMMMMMMM +MMMMM
:sMMMMMMMMMMM MMMMM
MMMMMM `UOJ
`sMMMMMMMMMMMMM+ MMMMMM
:sdMMMMMMMMMM MMMMM
MMMMMM `UOJ
MMMMMM
+MMMMM
MMMMM
`UOJ
Atlassian Jira
Version : 8.5.1
If you encounter issues starting or stopping JIRA, please see the Troubleshooting guide at https://docs.atlassian.com/jira/jadm-docs-085/Troubleshooting+installation
Server startup logs are located in /opt/atlassian/jira/logs/catalina.out
Using CATALINA_BASE: /opt/atlassian/jira
Using CATALINA_HOME: /opt/atlassian/jira
Using CATALINA_TMPDIR: /opt/atlassian/jira/temp
Using JRE_HOME: /opt/atlassian/jira/jre/
Using CLASSPATH: /opt/atlassian/jira/bin/bootstrap.jar:/opt/atlassian/jira/bin/tomcat-juli.jar
Using CATALINA_PID: /opt/atlassian/jira/work/catalina.pid
Existing PID file found during start.
Tomcat appears to still be running with PID 14069. Start aborted.
If the following process is not a Tomcat process, remove the PID file and try again:
UID PID PPID C STIME TTY TIME CMD
jira 14069 1 0 04:48 ? 00:02:01 /opt/atlassian/jira/jre//bin/java -Djava.util.logging.config.file=/opt/atlassian/jira/conf/logging.properties -Djava.util.logging.manager=org
jiracodeplait@jira.codeplait.net [/opt/atlassian/jira/bin]# ^C
Did you try to kill the PID and then do systemctl jira stop?
systemctl status jira to make sure it stopped.
Best,
Fadoua
Do you know, why we will have this error? I met the same issue as @malin.jayaweera
Usually we manually kill pid. but i really want to know, why we will have this issue? We want to fix this issue and won't manually kill the Pid
Morning @Mandia
A stale PID file failed to clear and is preventing startup.
It happens, it is a very common issue with TomCat. Explaining more is beyond my skills. May be a System Administrator can explain to you what happens exactly in TomCat.
All the best,
Fadoua
