Transition Post Function doesn't work
Aliaksandr Mikhailouski October 16, 2018
Standard jira Post Function functionality was used but this doesn't work with the current flow.  The same situation with Validation. But some points of these functions work. And I can't understand why it's so.
I have an admin permissions.
Angélica Luz
October 16, 2018
Hi Aliaksandr,
Can you please share with us what post function is not working?
If possible, send us a screenshot of the post functions from the affected workflow.
Was there any change before the post function stopped working?
Angélica
Aliaksandr Mikhailouski October 19, 2018
1st post function doesn't work. Status changes but the field value remains as it was.
Angélica Luz
October 23, 2018
Hi Aliaksandr,
I've tested here and also checked for some tickets and the post function to clear the value of remaining estimated is not supported.
It shows this error on my test instance:
Issue field "timeestimate" is not supported for setting.
To fix this issue, please follow the steps below:
1 - Go to the workflow.
2 - Remove the post-function The value of the field Remaining Estimate will be cleared
3 - Click on Add post function
4 - Choose Update Issue Field and click Add
5 - Select Remaining Estimate for Issue Field, and leave the field for Field Value empty
6 - Click on Add
7 - Publish the workflow
Please, give a try and let us know how it goes.
Angélica
Aliaksandr Mikhailouski November 1, 2018
Hi Angelica! My problem was solved by your explanations. Thanks a lot.
Angélica Luz
November 2, 2018
You are always welcome Aliaksandr!
We are glad that everything is working.
If you have any other question, please count on us.
Angélica
