is there any restrictions on the order of property keys shown in transition properties when change workflow ?
I used jira.field.resolution.include to control resolution selection list for different type of issue; but didn't see the result after I did -
which part went wrong ? I can see workflow A still working fine, but workflow B not; however, the only change I did in B was to get rid of one resolution ID, so users have less to choose.
jira.field.resolution.include does not exist. You can find the following ticket:
