Hi Community,
I encounter a problem (the script failing ungracefully) when trying to transition an issue from ScriptRunner.
There is no error code, it is like the script is just abandoning at issueService.transition(). I get the same behaviour when using issueManager.updateIssue().
Funnily the issue gets transitioned but the script fails to continue. The try/catch-block fails too.
I have another issue (other project), where the issueService.validateTransition() is causing the fail.
Could it be that there is an error with custom fields and newIssueInputParameters?
This is my code:
import com.atlassian.jira.bc.issue.IssueService
def issueService = ComponentAccessor.issueService
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def issue = issueService.getIssue(user, "FOSS-14")
if (!issue.isValid()) {
log.error("invalid issue")
return
issue = issue.issue
log.error("0")
try {
def action = 21
def issueInputParameters = issueService.newIssueInputParameters()
log.error("1/2")
def validationResult = issueService.validateTransition(user, issue.id, action, issueInputParameters)
log.error("1")
if (!validationResult.isValid()) {
log.error("invalid transition")
return
log.error("2")
def transitionResult = issueService.transition(user, validationResult)
log.error("3")
if (!transitionResult.isValid()) {
log.error("failed transition")
return
} catch (Exception e) {
log.error(e)
log.error("warning")
Output is:
2019-05-22 15:26:32,459 ERROR [runner.ScriptRunnerImpl]: 0
2019-05-22 15:26:32,459 ERROR [runner.ScriptRunnerImpl]: 1/2
2019-05-22 15:26:32,461 ERROR [runner.ScriptRunnerImpl]: 1
2019-05-22 15:26:32,461 ERROR [runner.ScriptRunnerImpl]: 2
Thanks for any input!
Hi @fuzzelmukkel ,
Are you using this script in the create postfunction ? Caused me issues before.
Anyway this is the code I use to transition an issue and it has been working fine so far :
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl
import com.atlassian.jira.util.JiraUtils
def transitionId = 21
WorkflowTransitionUtil workflowTransitionUtil = ( WorkflowTransitionUtil ) JiraUtils.loadComponent( WorkflowTransitionUtilImpl.class );
workflowTransitionUtil.setIssue(issue);
workflowTransitionUtil.setUserkey(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser().getKey())
workflowTransitionUtil.setAction(transitionId);
workflowTransitionUtil.progress();
Antoine
