Transition restriction for a project
Andrei Ionut Sandu August 10, 2022
On the actual workflow we have this trigger and some post-functions which are generating 5 types of sub-tasks.
Can I add any condition, validator or post functions to exclude this trigger rule from a project?
Let's say I have 10 projects which are using the same workflow...I want the 11th to use the same workflow but without this trigger associated to it.
Thank you,
Andrei Ionut Sandu September 5, 2022
UP! Any other solution? Thank you,
Andrei Ionut Sandu August 12, 2022
There is no other solution?
Shivakumar Hiremath
August 10, 2022
Hi Andrei Ionut Sandu
since Conditions, validators, and permissions will be ignored for automatic transitions. Only solution is copy the workflow and remove Trigger and associate to project
That's bad :( I would like to keep that project in the same workflow.
